Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E46 (1999-2005)
fan noise when ac is on
Hi, I have a 2006 BMW 325i. When I turn the AC on the cooling fan turns on too and oscillates at a high speed causing a pretty loud noise. Is that normal? I don't see a co-relation between AC and cooling fan.
Old 09-09-2014, 07:04 AM
The electric fan will always come on when the AC is on. It should just be a mild whirring sound, however. If you cannot see the cause of the noise (foreign object in fan, broken brace arm, etc.) then it is probably time for a trip to the junk yard for a different fan.
Old 09-23-2014, 06:09 AM
Andrea Bichael
I think you should replace the fan and that will be the best solution for this.
Old 09-24-2014, 05:56 AM
