'02 325 Oil drain plug
Does any one know the torgue value for the oil drain plug. I don't want to take the chance and strip the threads by simply snugging it up. I don't have a manual although I plan to get one soon, but want to change the oil and filter. The pan looks like it my be aluminum and my past dealings have been strip city. Any help is appreciated.
Author of "101 Projects"
I would start with about 10 N-m, and see if it leaks. I don't have the torque specs, but that should be so low that you shouldn't have a problem to start. Don't go over 25 N-m...
-Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
In the shop at Pelican
Also remember to always replace the drain plug washer at the same time. I personlly have had to weld and re-tap oil pans because of this. That little washer, if re-torqued can start leaks and in my case, (no pun intended) started cracking the oil pan.
