2006 325i crank no start
cas a0b4 fault engine start starter
dme 2a9a cam sensor intake signal dme 2aa0 cam sensor intake signal dme 2aa1 cam sensor outlet signal dsc 5e1a can dme/dde signal error |
fuel pump works but i have noinjector pulse and no spark?!?help please
Administrator
Hello and welcome to the forum! I found the following:
So 2aa0 refers to the Inlet which would be the intake camshaft sensor and 2aa1 refers to the exhaust camshaft sensor. They are located right next to each other. Just replace the one pertaining to the code and your set! Graph for visual help: ![]() |
