Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Upper Radiator Hose Install 08 E92
Good Morning,
Does anyone know if the coolant system should be bled if only installing a new Upper Radiator hose?
Thanks for your help.
Old 06-29-2022, 03:28 AM
Administrator
Matt at Pelican Parts's Avatar
Hi JL082!
If you check out our DIY articles we have many informational ones on the E92! In particular I found one for flushing the cooling system. If you scroll down to figure 8, you will find tips on using the bleeder screw to extract air from the cooling system.:
https://www.pelicanparts.com/BMW/techarticles/BMW-3-Series-E90/WATER-Draining_Filling_Cooling_System/WATER-Draining_Filling_Cooling_System.htm
Hope this helps!
-Matt
Old 06-29-2022, 11:14 AM
Thanks Matt!
Old 06-29-2022, 04:26 PM
