Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Ben (guest)
Guest
Posts: n/a
Hi I have a 2006 325i n52. I'm getting code p0341 that says I need to replace camshaft sensor bank 1. I replaced both sensors and the car still won't start. I replaced the crankshaft sensor and I pulled out the spark plug to test for spark, it sparked up just for a second. I put the spark back inside and tried to start again and nothing. Just cranks and doesn't spark. Coils are good, spark plugs are brand new, it's getting plenty of fuel. All I can think of is maybe wiring?
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Crankshaft Position Sensor Replacement
Old 12-07-2015, 06:13 AM
Nick at Pelican Parts's Avatar
If you have fuel and no spark, the issue likely a faulty DME. First confirm you have good compression and mechanical engine timing is correct. Then check the DME.
- Nick
