Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 3-Series E90 (2006-2012)
Tamas (guest)
Guest
Posts: n/a
The fault code is 2c24 o2 sensors interchanged I tried to swappe it but even worse after
This post was auto-generated based upon a question asked on our tech article page here: BMW E90 Oxygen Sensor Replacement | E91, E92, E93 | Pelican Parts DIY Maintenance Article
Old 02-09-2017, 09:09 AM
You should check for an exhaust leak, sometimes the computer may think the sensors are mixed up due to outside air entering the exhaust stream. Also I have seen misfires cause that fault. Have you verified that all the ignition system is functioning properly?
- Casey
