Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Question First step in finding gremlins?
in all of my other cars...VW's...gremlins were easy to find. But with all these wires in the BMW ('88 528e) I'm daunted! Seems every idiot lite is on and the windows just dont go down. I remember they used to, when my roommate first got the car a few years back. But ever since he had the power seats fixed, the windows stopped working. Should I just take it in? Or do I pull up the dash and start poking?
Call your old autoshop teacher and say "Thank you"
Old 03-06-2003, 11:22 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Sounds like a relay or switch may be bad. I would also check that the window lock-out switch is on.
Old 03-06-2003, 11:23 AM
The lock out switch? Where is that?
Old 03-06-2003, 11:27 AM
It should be on the shift column near the window switches.
Old 03-06-2003, 11:28 AM
Senior Advisor
Javier at Pelican Parts's Avatar
Actually it should be lower part of the dash. just right of the steering colum abou 1" x 1/2", its a breaker just push it in, if not check fuses.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 03-06-2003, 12:16 PM
oops Jav is right. I was thinking 3 Series
Old 03-06-2003, 01:57 PM
Bob540iA's Avatar
There are two switches that lock out the window motors.
The one on the console between the drivers side front and rear power window switches is to lock out the rear only.
The one on the kick panel under the dash just right of the steering column is a circuit breaker that disables all the windows. This is more likelty the cause. It is intenended as an overload protection.
Bob M
1995 540iA
1988 535i 5 Speed
1980 528i 5 Speed
1980 528iA
Old 03-06-2003, 02:00 PM
I pulled the dash back and checked that switch...it wasnt popped out, so maybe I have a short somehere.
Old 03-06-2003, 02:48 PM
My buddies dad that owned the car before me, said the he had fixed the power seats, and thats when the windows stopped working. So is there a main cluster under the passenger seat for the windows? Thats the only thing he messed with.....he says...
Old 03-10-2003, 10:38 AM
Okay..so maybe the button is pressed out. But when I push it back in (the breaker to the right of steering coloumn) it doesnt stay in. Do I need to replace the part? Or is there a way to fix this part myself?
Old 03-14-2003, 12:42 PM
Have you tried cleaning the switch
Old 03-14-2003, 12:44 PM
Its the cicuit breaker you guys told me about, behind the panel, to the right of the column. The little white button pushes in and comes back out. Its an outta sight part so its very clean. Do I just need to replace this breaker?
Old 03-15-2003, 11:00 AM
I'd give it a try and see if it solves the problem.
Old 03-17-2003, 09:41 AM
