Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
RazorRacer's Avatar
535 poor gas mileage
Recently the '88 535is started hunting for idle upon cold start-up and getting 10 mpg instead of the 20 mpg before. There is also an odor of gas sometimes. I've searched for a gas leak, but haven't found anything (but heah, I'm still looking for the fuel injectors and spark plugs).
Perhaps this is a common problem on these cars. Any help would be appreciated.
Stopped racing and became a drummer
Old 12-30-2002, 05:21 PM
RazorRacer's Avatar
Wayne,
The article says BMW's from 1992-1995 were equipped with an OBD I. I have a 1988 model. I did try to pump the gas pedal 5 times, but nothing appeared on the display.
Do I need to purchase a scan tool? Do the 1984-1991 model give any diagnosis?
Old 12-31-2002, 02:08 PM
Author of "101 Projects"
Wayne 962's Avatar
Your car is right on the edge of the year change. The article should say all E36 BMWs - 3-series, not all BMWs from 1988. I'll have to change that...
The scan tool does work for all 1988-2000 BMWs - I would recommend picking one up...
-Wayne
Old 12-31-2002, 02:13 PM
RazorRacer's Avatar
Wayne,
I have an E28. Should I get the code display after pumping the gas pedal 5 times?
Old 12-31-2002, 02:33 PM
Wayne 962's Avatar
Your DME should be version 1.0. I believe that worked with all Motronics version 1.0 and higher.
Whoops, I'm wrong. 1.0 cars doesn't work (no check engine light). 1.1 cars do. I guess you need the code reader. We sell it for $139 - it's a good investment...
Here's a link:
http://www.pelicanparts.com/cgi-bin/autocat/load_page.cgi?page_number=1&bookmark=1&model=BE12&currsection=electr
-Wayne
-Wayne
Old 12-31-2002, 06:16 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Have ou checked the obvious things, like plugs, rotor, wires? This could also be an indication of a bad O2 sensor. Has this problem been slowly getting worse or has it just instantly popped up?
Old 01-02-2003, 12:59 PM
RazorRacer's Avatar
It just popped up. The idle surging on start-up is probably a low battery. I am smelling gasoline, too. So there is probably a fuel leak.
What are common sources of fuel leaks? What is a good method for checking? I'm leary of using an open flame to check for it
Old 01-03-2003, 07:22 AM
Wayne 962's Avatar
CRIPES! Who gave you that suggestion?!?!? That would be the dumbest thing to do. Don't use an open flame - just use your eyes and your nose. Is the car running super-rich? That may be the smell...
-Wayne
Old 01-03-2003, 10:46 AM
Kinda OT, but in some of the Haynes manuals, there is a disclaimer.
Please Note, any reference to a "torch" in this manual refers to a flashlight, not a incindiary device or a welding torch
Guess all the manuals must have been printed in the UK.
Based on what you're describing, it sounds like the O2 sensor might be going out. Here's an easy way to test it. Start the car and let it warm up. Next, remove the oil filler cap to simulate a rich running condition. The O2 sensor at this point would normally start to have flucuating voltage btween it's terminals. This is because the O2 sensor is trying to compensate for the air leak. What you need to do is measure the voltage between the terminals. If you dont see fluctuating voltage, that is an inidcation that the sensor is bad.
Anyway
Old 01-03-2003, 10:53 AM
RazorRacer's Avatar
I'm leary of using an open flame to check for it.
That was a joke. But how do you adjust the mixture on this car? Is there an article or thread about it somewhere on this BBS?
Old 01-03-2003, 10:54 AM
I dont believe that you can adjust the mixture on these cars because of the Motronic system. I'd check the O2 sensor first, from what you describe it sounds like this may be the culprit.
Old 01-03-2003, 10:57 AM
RazorRacer's Avatar
will do. thanks.
Old 01-03-2003, 10:58 AM
Bob540iA's Avatar
The e28 535i uses OBD1 and does not store codes to my knowledge. The only thing you can do is reset the service LEDs on this version of Motronics.
A piece of wire to jumper two pins in the diagnostic conector will do the job of resetting the indicators.
If the diagnostic connector has 15 pins then its OBD1- 20 pins is OBD1.1
Bob M
1995 540iA
1988 535i 5 Speed
1980 528i 5 Speed
1980 528iA
Old 01-04-2003, 12:52 AM
RazorRacer's Avatar
Jared,
How do you measure between the terminals? I can't even get the friggen connector off .
Thanks.
Old 01-11-2003, 10:59 AM
RazorRacer's Avatar
Well I got the connector off by pulling twice as hard as I was pulling before. Still, I don't know how to measure the voltage with the sensor plugged in.
Old 01-11-2003, 11:09 AM
RazorRacer's Avatar
Basis this article the oxygen sensor generates it's own voltage so I just have to measure it at the connector, right?
Old 01-11-2003, 11:16 AM
