2007 E60 Heater problem
Good Afternoon; 2007 BMW 530i E60 (162k miles) heater issues. I am the third owner. Love this car! Heater will only heat 15-20 degrees above outside temp. After checking maintenance records, I find that this was an issue since day one (initial home was in Seattle, WA for 12 years). Dealer basically told owner to use defroster and wait. I have replaced thermostat and heater control valve all with zero improvement. AC works fine as does all the climate-control. Except heater. I am led to believe this is a quirk of the E60. IDEAS????? It was -12 today so I was a bit unhappy. Thanks...... |
You should post your question on the E60 section of bimmerforums.com
There are a lot more peeps there that can answer your question. I have an e39 540, that cooling system is a little bit different than yours. |
| All times are GMT -8. The time now is 04:38 AM. |
