Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Unhappy 2007 E60 Heater problem
Good Afternoon;
2007 BMW 530i E60 (162k miles) heater issues. I am the third owner. Love this car! Heater will only heat 15-20 degrees above outside temp. After checking maintenance records, I find that this was an issue since day one (initial home was in Seattle, WA for 12 years). Dealer basically told owner to use defroster and wait.
I have replaced thermostat and heater control valve all with zero improvement. AC works fine as does all the climate-control. Except heater.
I am led to believe this is a quirk of the E60.
IDEAS????? It was -12 today so I was a bit unhappy.
Thanks......
Old 12-21-2022, 03:22 PM
You should post your question on the E60 section of bimmerforums.com
There are a lot more peeps there that can answer your question.
I have an e39 540, that cooling system is a little bit different than yours.
2016 Highlander
1933 Factory Five Hotrod, LS3 powered
Old 12-24-2022, 05:39 PM
