-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Idle problem (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/123523-idle-problem.html)
glen-sj 08-15-2003 11:20 AM
Idle problem
I'm experiencing an idling problem with my 92, 525ia/M50 with 78K on the clock. At times when coming to a stop the idle would drop for a few seconds to around 500 rpm and the engine feel as it'll die. I've cleaned the throttle body, but that didn't help.
What would be causing this? Is there any adjustments that'll help? Thanks.
Humanoid 08-17-2003 03:30 PM
I don't know if it applys to your ride or not but I would find out if there is an idle control valve that may need cleaned or replaced.
vitifonz 08-18-2003 02:27 PM
I've same yr and model did the throtle body cleaning, changed the air filter and put stp in tank? But what made the big difference was changing the spark plugs!!! Old ones where filled with oil and sparks was not 100% on all plugs??? Took to a local BMW specialist and now have to replace rings where spark plugs are located...Hope this helps??
Jared at Pelican Parts 08-19-2003 01:14 PM
You also want to check all vacuum connections, valve cover gasket, as well as the coolant temp sensor. There is also a small vacuum hose under the throttle body for the emissions system that can cause this as well.
Exact-Oh 08-19-2003 03:05 PM
Yeah, what Jared said. I have had idle problems when the crankcase isn't totally sealed. It was very simple... the oil cap wasn't on all the way!
lewjw 08-24-2003 09:12 AM
I had the same (or worst): engine dies
Dealer repalced the MAF. "So far so good" for 3 weeks.
Humanoid 08-24-2003 01:25 PM
Re: I had the same (or worst): engine dies
Did they replace the sensor or the entire maf
Jared at Pelican Parts 08-25-2003 09:56 AM
I'd be suspect here, the MAF's are usually pretty reliable..
lewjw 09-03-2003 08:19 PM
It is the sensor which got replaced, not the whole MAF unit. Apology for being unclear.
Jared at Pelican Parts 09-04-2003 08:25 AM
what sensor? The O2 Sensor?
lewjw 09-04-2003 08:29 PM
Can you tell me what this is? p/n 13-62-1-433-567
