Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Send a message via AIM to PutterMcGavin
Gauge LCD & Parking Lights
Well finally I have the E34 looking great. Got the lower body and front lip spoiler painted as well as the Shadowline trim installed and I'm putting in some Bosch Stage III injectors this weekend. Unfortunately I have had an encounter with and infamous BMW electrical gremlin. Make that two problems. The first deasl with the LCD found in the dash cluster. If lights up fine when the car starts, but as soon as the car starts moving it goes VERY dim, or goes out altogether. Also when the key is turned to the point right before I turn it on the LCD it fine. Could this be a connection problem? My second problem is that my parkign lights aren't workign quite right. I think it might have something to do with the clear corners I'ver installed. The turn signals work correctly and come on every time, but the parking lights don't work like they're suppossed to. Fuses and all look fine but I'm a little stumped! Anyways if anybody has anything to help me then i'd greatly appreciate it! Thanks, James
**If any of you have some advice on how to install the fuel injectors that would be great as well (I'm already getting an air intake manifold, but is there anything else I should get?, etc.). Same for lowering springs installation.
Old 07-12-2004, 05:39 PM
