Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Heat Blows Cold When Idling
Well the subject line says it all. When the car is sitting at idle the heater blows cold air even with the heat set at 90.
AS soon as I start to drive off or if I rev the engine aprox. 2000rpm the the heat comes back to life.
Any ideas?
as always
db
Old 12-27-2006, 07:29 PM
Jeron's Avatar
Air in the cooling system. You'll find the procedure in the "tech info center".
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 12-28-2006, 12:13 PM
Thanks will check it out.
db
Old 12-29-2006, 05:42 PM
