528 water pump
I have a 2000 528 (E39) that has a noisy pump. It was replaced 18 months ago ... maybe they used a bad re-built. The bushing has no obvious play and it's not leaking but sounds terrible.
I'd like to change the pump but can't see an easy way of removing the shroud so I can get the fan off. Anyone have a good procedure to remove the shroud and fan? Thanks. '99 323 '00 528 '83 911SC |
I think I've seen write ups on E39 radiator removal but I'd have to search.
Are you certain it is the pump and not a pulley bearing?
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
I loosened the belt and the pulleys seem to be ok. I held a wood dowel against the pump and my ear and it sure sounds like the pump.
Thanks for any help.
1983 SC, blk/blk. |
Heres what the first two that came up when I searched:
http://www.bimmerboard.com/forums/posts/199986 http://www.bimmerfest.com/forums/archive/index.php/t-47093.html I'm sure there are others.
Thanks. I still don't see how to remove the fan without removing the fan shroud first. The fan shroud is the item that I'm finding most difficult to remove.
Thanks for the information. I'll print it out and go over it while under the hood.
1983 SC, blk/blk. |
I didn't read it but sometimes the fan is loosened and it is pulled up WITH the shroud.
