-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   e28 oil change(noob questions) (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/335963-e28-oil-change-noob-questions.html)
PDk 03-16-2007 08:50 AM
Alright, so I have gotten everything I need to do it, the pan to catch it, sockets, new STP oil filter, all the right part numbers. But im not quite sure where everything is. I *think* that the oil filter is in the housing by the coolant resevoir? And i dont know where the drain plug is exactly under the motor. TIA, and pictures would be terrific.
Jeron 03-16-2007 11:41 AM
Depending on your engine it looks like there is either a spin on or a cartridge filter. The spin on should be obvious when you find it. If it is a cartridge then it is probably on the drivers side of the engine near the front. Should be a metal lid with a bolt in the center.
http://www.pelicanparts.com/BMW/techarticles/E36-Oil-Change/E36-Oil-Change.htm
The drain bolt is at the bottom of the SIDE of the pan.
