Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
PDk PDk is offline
e28 oil change(noob questions)
Alright, so I have gotten everything I need to do it, the pan to catch it, sockets, new STP oil filter, all the right part numbers. But im not quite sure where everything is. I *think* that the oil filter is in the housing by the coolant resevoir? And i dont know where the drain plug is exactly under the motor. TIA, and pictures would be terrific.
Old 03-16-2007, 08:50 AM
Jeron's Avatar
Depending on your engine it looks like there is either a spin on or a cartridge filter. The spin on should be obvious when you find it. If it is a cartridge then it is probably on the drivers side of the engine near the front. Should be a metal lid with a bolt in the center.
http://www.pelicanparts.com/BMW/techarticles/E36-Oil-Change/E36-Oil-Change.htm
The drain bolt is at the bottom of the SIDE of the pan.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 03-16-2007, 11:41 AM
