2002 525i Oil Viscosity
I just changed out the Mobil1 5-30 with Mobil1 10-30. Sounds insignificant btu we are heading into cold weather and the Owner's Manual calls for 5-30 synthetic. Should I stay the course of change to 5-30 now? Basically, I am not sure how finicky these engines are.
CWL '88 Carrera Cab |
I wouldn't say the engine is finicky. I used to run 10w-30 summer and 5w-30 winter. I just run 5w-30 year round now in my E46.
I'd leave it unless you park outside at night. Take some solace in that Mobil 1 runs thinner than other brands.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
Thanks. I'll do as you say and let it go. Or I could just swap out the 10-30 from the crankcase and replace with 5-30. Easy, but without filter, a little incomplete. I must be bored to be worrying about this stuff.
If you just changed the filter there is no need to change it again.
