Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
tally
Oil Pan Removal
I am having difficulty removing oil pan from 1995 525i.
Bentley's book states that it can be done without removing
engine or suspension. I can not get it passed the suspension.
Am I missing something?
Thx
Tally
Old 01-28-2008, 06:51 AM
Jeron's Avatar
If it's like the E36 you have to drop the front subframe.
You don't actually remove anything but you have to support the engine from above and unbolt the engine mounts, steering column linkage and the front suspension in a couple of places to let it hang down.
The 5-series may be different.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-28-2008, 11:32 AM
tally
That sounds complicated. Can I remove Cross bar that transmission is
supported on instead? If I can drop this a inch I think I would be in
business.
Thx.
Old 01-28-2008, 12:38 PM
Jeron's Avatar
I'm not familiar with your model.
In general the problem is that the engine is mounted very low and the oil pump hangs down into the oil pan several inches so you cant slide the oil pan back without dropping it 4-6 inches which is prevented by the front subframe.
On the E36, dropping the tranny support would not help at all.
Old 01-29-2008, 07:20 AM
On an E30, you would actually loosen and drop the oil pump into the pan and then remove the pan with the pump in it.
Old 01-31-2008, 06:46 AM
