Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
'88 535ia-steering Pump Noise
I CHANGED THE STEERING PUMP BELT BECAUSE IT WAS WORN. THE HAD NO NOISE PRIOR TO CHANGING. AFTER THE BELT CHANGE LOUD NOISE ,I TRIED TO BLEED THE SYSTEM =NO CHANGE. I REPLACED THE PUMP WITH A GOOD USED PUMP AND BLED THE SYSTEM AGAIN. NOISE STILL THERE. I CHANGED THE STEERING FLUID FILTER ,ANOTHER BLEED AND THE NOISE WENT AWAY UNTIL THE NEXT MORNING . NO LEAKS -PLEASE HELP. I OWN THREE E28'S AND M635CSI AND HAVE NEVER HAD THIS PROBLEM WITH A STEERING PUMP.
THANKS IN ADVANCE.
Old 08-03-2008, 01:18 PM
Jeron's Avatar
What does the noise sound like? Are you sure you got the proper size belt?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 08-03-2008, 09:37 PM
535ia steering pump noise
THANKS RESPONDING
THE NOISE IS LIKE THE PUMP IS STARVING FOR FLUID. YES THE BELT IS THE CORRECT SIZE. ?????? THIS MY WIFE'S CAR-----H E L P
Old 08-14-2008, 03:59 PM
Jeron's Avatar
If the noise started because of the belt change it would have to be the belt or belt tensioner.
Old 08-15-2008, 07:17 AM
