Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
5-Series Front Strut Cartridge Replacement
I'm trying to replace the front strut cartridges on my 1989 525I. The car has 245,000 miles on the originals. I have removed the first strut, removed the coil spring, and also removed the retaining nut that holds the strut cartridge in the strut housing. My problem is the old cartridge will not come out easily. Any ideas or suggestions would be appreciated. Thanks, Bruce
Old 09-20-2008, 10:53 AM
Cartridge Removal
Since I didn't get any responses from the forum yet, I'm going to attach a lifting eye to the end of the piston rod and another lifting eye to the bottom of the strut housing. Then I'm going to attach one eye to the frame of my engine hoist and attach the other lifting eye to the boom of the hoist and apply about 4,000 lbs force. If that doesn't pull the cartridge out, I will attempt to heat the housing with a torch. If that doesn't work, I'll probably look for another strut housing.
Old 09-21-2008, 04:02 PM
My idea worked. I attached lifting eyes to both ends and pulled the cartridge out with hydraulic force. The cartridge was rusted to the strut housing for about the first inch.
Old 09-22-2008, 11:12 AM
Jeron's Avatar
I'm glad it worked.
When reading your second post describing how you were going to get the cartridge out, it reminded me of a mountain climber giving his route up a mountain. I expected you to finish with "and if you dont hear from me in a couple of hours call 911."
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 09-23-2008, 08:27 AM
