Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Head Bolts
Can't find inch ,lb torque setting for new head bolts 1995 525i 2.5 straight six
Old 04-25-2009, 04:13 AM
Jeron's Avatar
The head bolts are stretch type bolts. What you will probably find is an initial torque setting then two stages of tightening based on degrees of turn.
For expample, and this is just made up numbers: 30ftlbs > 90 Deg > 90deg
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 04-25-2009, 11:22 PM
Thanks for your responce. Just completed head gasket replacement machine shop repaired crack. Motor is steaming out tailpipe, So far I see no sign water in oil, could their be other reasons besides a failed repair of the crack by machine shop.
Old 04-27-2009, 09:35 PM
Jeron's Avatar
The steam could be normal for cold start in your the climate or residual moisture in the oil.
How much time have you given it to warm up? What color is the steam, white, blue? Does it smell sweet?
I would let it warm up, then drive it and keep an eye on the oil and coolant.
Old 04-28-2009, 06:19 AM
