-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   trans fail safe prog....... (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/489491-trans-fail-safe-prog.html)
samuraj 08-03-2009 04:43 PM
Automatic trans indicator lamp comes on...engine running with reduced power, when idling forward and reverse gears engage very hard, car has 140.000 miles , trans fluid never been changed (live time fluid:()
please give me not so bad news.:D:D
samuraj 08-05-2009 05:12 PM
$213.00 and visit at dealer cure the problem,
DME reprogrammed and KOMBI recodedhttp://forums.pelicanparts.com/suppo...ys/men_ani.gif
samuraj 08-10-2009 04:18 PM
.......OOPS problem again..:(:( trans failure light on , parked the car for the night.Next day .....runs fine again:confused::confused:
Time for trade.:cool:
samuraj 08-10-2009 04:19 PM
Nobody like me...........
Jeron 08-11-2009 08:42 AM
You have the 5HP19 tranny which has a common failure part.
http://www.noreverse.org/
http://www.bimmerfest.com/forums/showthread.php?t=336857
samuraj 08-11-2009 04:42 PM
:confused:reverse gear working fine, only when lite come back..shifts very hard.
Jeron 08-11-2009 04:55 PM
If you arent having any symptoms of a reverse drum failure then I would check the fluid level.
http://tech.bentleypublishers.com/servlet/JiveServlet/download/72-16089-142522-1634/B305_240.pdf
If that does not fix it, change the fluid.
Finally you will need to take it to a shop where they will either find an electrical issue or suggest you have the tranny rebuilt.
samuraj 08-12-2009 05:55 PM
checked the oil level..O.K.
samuraj 08-14-2009 04:28 PM
dealer replaced crankshaft sensor....now drives fine......where is my idea off extended warranty????? should listen my father..:(
Jeron 08-17-2009 08:54 AM
I would not have expected those symptoms to be the crankshaft position sensor.
Im glad you got it fixed.
samuraj 08-17-2009 05:47 PM
it is strange.....but now drives fine for second day... my guts telling me it is not over yet.......
