trans fail safe prog.......
Automatic trans indicator lamp comes on...engine running with reduced power, when idling forward and reverse gears engage very hard, car has 140.000 miles , trans fluid never been changed (live time fluid
)please give me not so bad news. ![]()
2001 530i black 2005 dodge ram hemi sport P1445 Big Hawg |
$213.00 and visit at dealer cure the problem,
DME reprogrammed and KOMBI recoded
.......OOPS problem again..
![]() trans failure light on , parked the car for the night.Next day .....runs fine again![]() ![]() Time for trade.
Nobody like me...........
You have the 5HP19 tranny which has a common failure part.
http://www.noreverse.org/ http://www.bimmerfest.com/forums/showthread.php?t=336857
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
reverse gear working fine, only when lite come back..shifts very hard.
If you arent having any symptoms of a reverse drum failure then I would check the fluid level.
http://tech.bentleypublishers.com/servlet/JiveServlet/download/72-16089-142522-1634/B305_240.pdf If that does not fix it, change the fluid. Finally you will need to take it to a shop where they will either find an electrical issue or suggest you have the tranny rebuilt.
checked the oil level..O.K.
dealer replaced crankshaft sensor....now drives fine......where is my idea off extended warranty????? should listen my father..
I would not have expected those symptoms to be the crankshaft position sensor.
Im glad you got it fixed.
it is strange.....but now drives fine for second day... my guts telling me it is not over yet.......
