-   BMW 5-Series E28/E34/E39/E60/F10/GT (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/)
-   -   Brake lining warning lamp does not go out (http://forums.pelicanparts.com/bmw-5-series-e28-e34-e39-e60-f10-gt/594786-brake-lining-warning-lamp-does-not-go-out.html)
g partida (guest) 03-02-2011 09:59 PM
I replaced the brakes on may 528i. 2000. And the dach light won't go off how do i reset it.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Resetting BMW Airbag Warning Lamps (SRS Reset)
Wayne 962 03-02-2011 09:59 PM
The brake pad sensors control this lamp. If the sensors triggered the lamp to begin with, then you must replace them (they are one-time use only). If they are brand new sensors, then the connector is probably not well seated in the plug. I would unplug and then replug in all of the sensors to make sure the connection is good.
- Wayne
CROWSC 03-03-2011 03:03 PM
Wayne is right on the money, I just did my brakes and had the same problem. Replaced the sensors and all is good now.
