starting problems
I have a 2001 BMW 540i sport with the 4.4v8 that wont start the motor spins over but wont fire before this problem everything ran fine but I had to park the car do to the reserve coolant tank needing to be replaced and then I left my glove box open and killed the battery but when I replaced it the motor would just spin over I got an OBD II and checked for errors but it didn't have any I was thinking that my fuel filter might be the problem but not sure can any one help
In the shop at Pelican
You probably disconnected something when you were replacing the coolant tank. Take a ghood look around the area and see that everything is hooked up correctly.
