Hey,
I am looking for a coolant level sensor harness end. Is there such a thing as a repair kit for just the plug end? Thanks. |
In the shop at Pelican
OK, what kind of car is it for?
yes, Pelican Parts has them, but first of all you have to clearly mention the model and built year and month, otherwise no one can help.
You can also use RealOEM.com Online BMW Parts Catalog to find out the part numbers. For example in case of my 11/88 E32 750iL Pelican Parts would sell me Snap-in receptacle 2.5 watertight 1,0-2,5 MM˛ 61130007446 these are pin with water tight connectiona nd some wire which you then can crimp into the old line or solder it in. and one of these: PLUG TERMINAL BLACK 61131378400 Plug housing 61131378401 Plug housing 61131378403 Plug housing 2 POL. 61131378402
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES http://twrite.org/shogunnew/topmenu.html |
