2001 525 oil leak question...HELP...!
anyone know what oil line this that is leaking at the "Y" shaped part of the line just above the engine oil pan it looks like...maybe the line is off the base of the motor but looks like the top of the oil pan...
**wooden ruler is touching the leaking line... Also, after we figure out what the leaking oil line p/n is, is this difficult/what is involved to replace this line...? thx a lot...bob ![]() ![]() ![]() ![]() ![]() ![]()
I live for 911 tweaks... |
anyone...? not much activity on this part of the pelican site...?
That looks like the dipstick tube.
The Y part is the PCV drain which comes down as a hose and joins the dipstick tube just before it enters the top of the pan. On that model BMW the PCV is called a Cyclone Separator and its plastic hoses and parts are a pain to deal with.
HPDE Instructor (BMW / PCA / Apex) Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4 |
thx jeron... I actually have been waiting over a week from the local dealer to advise what is this part... believe it or not...true...!
I was wondering if it may be the dip stick tube...car is not here now but from the quick inspection i wondered if it may be that... Q: have u ever replaced this tube/hose assembly...? if so, whats involved...? thx a lot for replying here...!! bob ))
The dipstick tube is easy to remove. The rubber drain tube will have to be pulled off of the metal dipstick tube and there may be a wire or tube that is strapped to the metal tube. Otherwise it is just has a single bolt at the top under the intake.
Once disconnected it just pulls out of the oil pan. There will be a O-ring that will probably stay lodged in the oil pan and it should probably be removed and replaced. You will have to remove the intake tubing of course but that is easy. RealOEM.com * BMW E39 525i OIL PAN/OIL LEVEL INDICATOR Your oil leak could be from the o-ring at the bottom of the dipstick tube or coming down from the brittle cyclone separator tubing above.
thx jeron...great info...
yeah I was wondering if one or some of the brittle plastic oil vent/suction tubes are involved here AND will they break in the process of the repair...Probably a good ides to replace now if questionable... thx again & I will post pics when the car is back & i do the repair... bob
