Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
jj (guest)
Guest
Posts: n/a
07 bmw525 intermittent leak when running. I pulled the bottom cover off and can't seem to locate the source. even running, the leak isn't consistent. any ideas ?
This post was auto-generated based upon a question asked on our tech article page here: BMW E60 5-Series Cooling System Leak Test (2003-2010) - Pelican Parts Technical Article
Old 02-14-2017, 09:47 AM
Yeah I have found that its easiest to find the leaks on these cars if you pressurize the system using a pressure tester and cap adapter WHEN COLD. The thermal expansion tends to seal up the leaky areas as the car warms up.
- Casey
