Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 5-Series E28/E34/E39/E60/F10/GT
Testing ABS Wheel Speed Sensors
Something I found useful if you are testing the individual wheel sensors is to slip a length on 1/16" copper tubing over the pins to extend them outside of the sensor plug and permits better checking in the sensor with a VOM.
Old 06-14-2017, 07:05 AM
Administrator
Dmitry at Pelican Parts's Avatar
Thank you for sharing this info, I'm sure other members will find it useful.
Old 06-14-2017, 10:14 AM
Thanks, Dimitry, can you check my ABS Error code post and see if you can give me any info re error code 40 from ABS model. What is the "gas valve"
Old 06-14-2017, 11:17 AM
Administrator
No problem, glad to help! Unfortunately I wasn't able to find much info on code 40 - Gas Valve - Potentiometer Error. Hopefully some other members will chime in.
Old 06-15-2017, 11:55 AM
abs error code
I think it is the pot on the secondary throttle butterfly for traction control.
Old 06-15-2017, 11:59 AM
