Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
BMW Roundel Oil Change Indicator
I recently had the oil changed in my '88 735i but the status bar under the speedometer is still telling me that I need service. Is there a way to reset that light without visiting a BMW dealer? Any assistance is appreciated. Thank you.
Lael Sturm
Old 01-28-2003, 08:39 AM
Senior Advisor
Javier at Pelican Parts's Avatar
pelicanparts sells the re-set tool for your model. 49.95 plus s/h. . thanks.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 01-28-2003, 09:37 AM
KC Ron Carter's Avatar
BMW Roundel Javier is giving good advise
But to test if the batteries need replaced try the following.
With the ignition switch at (position two) and the engine not running, grounding pin seven #7 of the diagnostic connector to pin one #1 for approximately three (3) seconds will reset the oil service lights. Grounding pin seven #7 to pin one #1 for approximately twelve (12) seconds will do an inspection service reset.
http://www.unofficialbmw.com/images/reset1.gif
1. Ground
4. Temperature sensor
7. Reset
8. TDC sensor yellow
9. TDC sensor shield
10.TDC sensor black
11.Start signal
12.Alternator charging excitation voltage
13.Ignition coil
14.Alternator charging supply current
15.Oxygen sensor output to test with.
It will signal an oil change need between 5k and 7k depending on your indicated speed since the last reset. It will signal stealer inspections at all the predesignated miles.
http://www.eskimo.com/~dalus/bmw/e36/electrical/e36_reset_service_lights.html
Old 03-10-2003, 08:44 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
I dont reccommend this method of resetting the computer, because it can send spikes through the wiring and fry your ecu. There have been a couple of people I know personally who have done this. Use the tool, dont take a chance. The tool is $49.95, a new ecu is over $500.
Old 03-11-2003, 08:55 AM
The SI board has nothing to do with the ECU.
I am ASE certified and may suggest your experience to recommend a difference to my recommendation is kind of strange.
Please concider posting the e-mail address of either owner that had an issue.
Later,
Old 03-11-2003, 09:44 PM
KC,
I post this warning because I have seen this failure before. The Si Board and the ECU are not directly related, however thats not what we are talking about here. When you try to ground out the pins on the diagnostic connector, it can send voltage spikes through the car, which can damage the ECU. If this isnt the case, why have I sold two new ECU's to customers who tried to reset the indicator this way?
I would like to state for the record that Pelican does NOT reccommend you reset the indicator in this way. ALWAYS use the tool.
Old 03-12-2003, 09:12 AM
