Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
My shifter is stuck...
Long story short, I pulled my console out a couple of days ago and was pulling the shifter around while doing it, and when I finally got the console out the right way, the shifter is jammed up now.
I have a 1980 635csi Euro with the dogleg trans. I seems to be stuck in the forward left gear, which I'm not familiar with yet, as I just acquired the car. I tried rocking the car while wiggling the shifter, but it didn't help.
What can I do?
Thanks,
Cale
Old 05-11-2004, 07:03 AM
In the shop at Pelican
Jared at Pelican Parts's Avatar
IS this a manual or automatic?
Old 05-19-2004, 12:43 PM
It is the close ratio manual box.
Old 05-20-2004, 12:06 AM
And you cant pull it down?
I would check all the linkage to make sure that nothing is caught in there, preventing it from moving.
Old 05-20-2004, 06:08 AM
I got under the car and there is nothing touching the linkage that looks out of place... I can't figure it out....
Old 05-20-2004, 12:11 PM
Did you check all the joints to make sure they are not siezed?
Old 05-24-2004, 02:37 PM
They don't appear to be...I had rowed through the gears several times before that to see what it felt like. I did find out though that the previous own had installed a short throw shifter, if that makes a difference.
Cale
Old 05-25-2004, 11:34 AM
That may be the problem...
