Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Weird coolant leak on '88 M30, any help much appreciated.
I have an '88 735il with the M30 6 cylinder. The car has 147k on it and I recently replaced all the belts and hoses. I bled out all the air and everything was going perfectly until a week later the water level started to come down. The next day lots of water was coming out of the area of the rear of the head. I tried to see exactly but there is little room. I'm hoping that the water isn't coming from the head gasket. I also felt a metal plate on the back of the head. Has any one had a similar problem and what was the fix on it?
Thanks,
Russell
Old 12-06-2004, 02:53 PM
Still Doin Time
asphaltgambler's Avatar
Best thing is to obtain a small dental style mirror with a flexible head to get behind there and see exactly where it's leaking. They can be obtained from auto parts store.
Old 12-07-2004, 11:41 AM
You're right, it seams like the only real positive way to figure it out. I was just hoping someone was unfortunate enough to have had the same problem. Thanks for the response.
Old 12-07-2004, 12:16 PM
In the shop at Pelican
Jared at Pelican Parts's Avatar
Could be one of the heater hoses in the back.... or a bad heater core....
Old 12-08-2004, 09:42 PM
The problem ended up being a blown head gasket. I haven't seen one fail like this one did but a little hole developed and thats were the leak was at.
If I get the head surfaced must I get the thicker head gasket?
Old 12-13-2004, 09:24 PM
Still Doin Time
I would have the machine shop check it first for warpage. No problem taking .008-010" off, just a clean-up if needed.
Old 12-23-2004, 06:32 AM
