Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
BigRick50's Avatar
94 740IL Locks
The battery on this car has died (guess I should drive it more often) and now I can't open any of the doors. The key turns in the locks (both front doors and the trunk) but the locks don't disengage. I called the dealer and their service people told me that there is an exterior release under the door handle (never found it) and that there is an exterior hood release that can be accessed with a coat hanger above the driver's side headlight (can't find that either). I'd appreciate any help as to how I can hook up a battery charger when I can't get in the car, or how to get into the car so that I can recharge the battery.
Old 12-31-2006, 09:57 PM
Jeron's Avatar
Here are instructions from a E34 owners manual. I'll bet yours is the same. It appears you lift the handle, then turn the key harder than normal in he unlock direction.
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 01-02-2007, 06:37 AM
BigRick50's Avatar
Thanks very much for the assistance Jeron, but it didn't work. I lifted the handles (both driver's and passenger's side) and twisted the key as hard as I dared, but no luck. I guess I'll have to jack the car up until I can find a hot wire I can use to charge the battery. Oh well... another project for the upcoming weekend.
Old 01-03-2007, 08:44 PM
Jeron's Avatar
Try the starter or the alternator for a good hot wire.
There must be a way to get the hood open.
Or better yet read this:
http://forums.bimmerforums.com/forum/showthread.php?t=645130&highlight=battery+trunk
Old 01-04-2007, 07:42 AM
u have 2 use the pass door & turn key & pull handle at the same time
Old 01-07-2007, 05:25 PM
Send a message via AIM to Bear
Locked Doors
Go here
http://www.bmwe32.masscom.net/maxf_website/freeyellow.com.htm
Old 01-10-2007, 03:19 PM
doors locked
http://www.bmwe32.masscom.net/maxf_website/freeyellow.htm
Old 01-10-2007, 03:21 PM
doors locked
I cannot get the URL part thats should read maxf_website/freeyellow.com to print out correctly but there are procedures there to get her unlocked. After I got mine unlocked I added a wire around the hood release cable at the jaws with a finger loop above the drivers side high beam so I could yank the hood release open if i got stuck.
Old 01-10-2007, 03:26 PM
