-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   735i Valve noise (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/333878-735i-valve-noise.html)
darren911sc 03-05-2007 03:16 PM
735i Valve noise
Valves seem loud, is there a valve adjustment that is done? I haven't dug into Bentley Publishing yet.
hyperjam 43 03-17-2007 10:19 AM
I have three of these cars and they usually sound like demented typing pools.This is quite common and not really a problem.It is caused by incorrect valve clearance or worn camshafts.Valve clearance is set by turning discs on the rocker arm.I do it using a tool I made from a wire coat hanger.It is quite easy if a little time consuming. Here is a link http://www.bmwe34.net/e34main/maintenance/engine/valve_adjust.htm
