Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
735i Valve noise
Valves seem loud, is there a valve adjustment that is done? I haven't dug into Bentley Publishing yet.
Old 03-05-2007, 02:16 PM
I have three of these cars and they usually sound like demented typing pools.This is quite common and not really a problem.It is caused by incorrect valve clearance or worn camshafts.Valve clearance is set by turning discs on the rocker arm.I do it using a tool I made from a wire coat hanger.It is quite easy if a little time consuming. Here is a link http://www.bmwe34.net/e34main/maintenance/engine/valve_adjust.htm
Old 03-17-2007, 09:19 AM
