Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
85 e23 pulling when braking
Car is 1985 735i. Just replaced both front calipers. I have bled all wheels several times (pump and bleed, no pressure or vacuum). Pedal is soft and car will pull sharply to the right when the brake is applied. If I get right back on the brakes after the initial braking, the car does not pull nearly as bad. Had good fluid flow at all bleed points. Kept fluid in reservoir at all times.
Any ideas? Thanks.
Old 10-13-2007, 12:29 PM
3.2 CAB's Avatar
Did you also install new pads? Did you also flush and drain old brake fluid? It almost sounds like there is still air in the left side of brake system, or the pad sliding surfaces in the caliper are dry and need lubed. I would try to do a deep bleeding on it a time of two more, after checking these other items. Good luck, Tony.
84' Steelslantnose Cab.
1953 Dodge B-4-B-108" 90,127 miles
1953 Dodge B-4-C-116" 58,146 miles
1954 Dodge C-1-B8-108" 241V8 POLY
1973 Roadrunner 440-SIX-PACK*
1986 F-250 Super Cab-460 V8 tow
Newest additions-
Matching numbers 1973 340 Road Runner!!
1948 Dodge B-1-F-152" 1-1/2 ton Dump body, 39,690 miles
others...
Old 10-14-2007, 10:23 AM
Jeron's Avatar
I take it, it did not do it before the brake change?
HPDE Instructor (BMW / PCA / Apex)
Here: 1997 M3/4 Byzanz/Magma ~ 2006 Yamaha R6 ~ 1997 R1100RT ~ 1991 Ford F-150 5.8l ~ 2015 Kia Optima
Gone: 2001 330i Silver/Grey ~ 98 Camry V6 ~ 97 Camry I4 ~ 97 Mazda 626 I4 ~ 93 Sentra SE-R ~ 88 Toyota Truck I4
Old 10-14-2007, 07:38 PM
