Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
greasemonkey's Avatar
840i transmission issue
Any ideas - car starts and runs fine. But, when pulling away, it's as if the clutch were slipping in a manual car - the revs rise but the car is very slow pulling away. Finally when it gets to cruising speed, the car is fine. It went into limp home mode after the gearbox started playing up.
Where do I start to look?
1974 911s (Backdated to RS Clone), 2006 Cayman S, 1963 MGB
Old 09-15-2013, 12:26 PM
shogun's Avatar
check the trans fluid level, that is the first step, at the correct temperature and shifting thru the gears. Here is the procedure
http://www.europeantransmissions.com/Bulletin/DTC.BMW/BMWtransService.pdf
Look at the U.K. E32 forum, I just posted how to clean up the valve body
The 7 Series Forums
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 09-16-2013, 03:19 AM
