Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
teebeema (guest)
Guest
Posts: n/a
Hi Wayne!
I have a 95' 750 il and lately i have noticed this clicking noise from the engine. Turned out it is coming from the climate heater valves. Giving me constant sounds like on and off but it does not happens every time. Just sometimes. other thing is i found my fuel tank leaking... Do you have any suggestion on that one?
Few electrical issues as well, mostly my fuel level does not accurate . After fill up it shows around 60 liters,but goes down to 0 ,light comes up etc. Look empty. Next day it does show about 45 liters again. Annoying right? Any suggestions are appreciated. Thanks
This post was auto-generated based upon a question asked on our tech article page here:
Old 08-28-2013, 03:52 AM
Nick at Pelican Parts's Avatar
Are you saying your fuel tank has an external leak? If one side of the tank is leaking, the fuel level will display incorrect until the siphon can fill that side back up. Repair the external leak and the problem should go away.
- Nick
kens_74_911s's Avatar
bad readings at cluster
I have something similar on my 96 750iL only mine seems to be related to OS temp and engine temp that never changes. A battery pull reset and it captures current reading on reconnect. Fuel tank did similar but tank popped back to normal when I filled it up on its own. i am going to look into body K bus , it may be my cluster. Have you tried to unlock the cluster function and check tank levels there ? I would be curious to also know your inst voltage as mine says 6.8 but probing all pins ( breaking them out at connectors ) I get 13-14V. K
Ken - ebay: wandrey1 , *0 , *00 , *01
74 911s NA Widebody /96 BMW 750iL /99 BMW 328i/ 2018 BMW X3
81 VW Caddy Pickup X2 now...
84,85x2 .86,87,944. 82-924,88-924s parted with inventory!
68, 70, 72, 73, 911~ 70,73 914 past P/cars
Old 10-05-2013, 06:53 PM
