Guest
Posts: n/a
i bought a used dme for my bmw 1997 740il when i plug it in the engine turns over but wont start i got it for a spare the original one is ok they both have the same numbers on them dose it have to be coded or should it just go in and start i havent paid for it yet i dont know if i am doing something wrong please help thank you al
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW DME Motronic ECU Swap / Repair |
Author of "101 Projects"
I'm pretty sure that with the 1997 7-Series, you need to have the immobilizer coded to match the DME. So, a simply plug-and-play solution is not going to happen, unless you have all of the codes for your car and have it programmed by someone with the proper software tools.
- Wayne
Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports |
