E32 735iA camshaft removal ???
Hi !!!
On my 735ia E32, my camshaft isn't in good health ... should I change it ? Does camshaft will broke soon ? ![]() I bought a new camshaft, and 12 new rocker arms. Is it hard to do it ? Does someone have informations ? pictures ? I think I will have to remove head gasket to change these parts seriously ... does someone already did it ? Thanks for answers. |
DIY rebuilding procedure for M30 head
M30 Cylinder Head FAQ M30 Headgasket replacement, part 1 M30 Headgasket replacement, part 2 ask here Bimmerforums.com BMW Online Forum dedicated to owners suspension brakes handling power turbo on the E32 forum. Best is you buy a Bentley Repair Manual for the BMW E32, Pelican Parts has it.
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES http://twrite.org/shogunnew/topmenu.html |
In the shop at Pelican
I doubt it will snap in half if that's what you mean. That picture really doesnt help me in seeing whats wrong with the cam. It's too dark and out of focus.
Changing the camshaft requires removal and complete dis-assembly of the cylinder head. You also need to have a valve job done at the same time. You can change the cam yourself, you'll need to have a machine shop do the valve job. However, the machine shop will install the cam and rockers at the same time. Last edited by Jared at Pelican Parts; 03-28-2011 at 08:38 AM.. |
