Guest
Posts: n/a
how to get fan belt back on 2001 740i? do have to take fan out? which is tension release nut?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Belt Replacement |
You do not have to remove the fan. Your engine utilizes two hydraulic tensioners. You will have to route the belt correctly, then release tension on the tensioner and install the belt.
- Nick |
