LinkBack | Thread Tools |
Guest
Posts: n/a
HI, i am working on a 2003 bmw 745li 4.4 and i changed the valve cover gasket on the drivers side now i am getting a code P0024 Exhaust B Camshaft Position - Timing Over Advance. does anyone know why this code is coming up. and also is there a way you have to set the timing actuator or servo motor ontop of the valve cover? Can anyone help?
__________________ This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW Camshaft Timing and Vanos Unit Installation |
The fault indicates a timing problem. If you didn't change anything except the valve cover gasket, it may a coincidence.
The Valvetronic motor limit stop has to be set using a BMW scan tool. - Nick |
