-   BMW 6,7,8-Series Technical Forum (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/)
-   -   1984 745i and if I ease into the throttle under a load I can get pretty good rpm"s before it starts loosing power (http://forums.pelicanparts.com/bmw-6-7-8-series-technical-forum/752124-1984-745i-if-i-ease-into-throttle-under-load-i-can-get-pretty-good-rpm-s-before-starts-loosing-power.html)
Red (guest) 05-25-2013 09:56 AM
I have a 1984 745i and if I ease into the throttle under a load I can get pretty good rpm"s before it starts loosing power and popping. but if I press petal to the floor it immediately starts popping and stalling. I have replaced the fuel pump.
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: BMW DME Motronic ECU Swap / Repair
Nick at Pelican Parts 05-25-2013 09:56 AM
I would check the DME for fault codes using a BMW scan tool. Start with what code is stored. This will likely get you to the source of your problem.
if none are present, check engine timing and backpressure.
- Nick
