Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
degee (guest)
Guest
Posts: n/a
95 bmw 850 shut off and does not start again
This post was auto-generated based upon a question asked on our tech article page here: Pelican Technical Article: Reading BMW Fuel Injection Fault Codes
Old 06-10-2013, 05:46 AM
Nick at Pelican Parts's Avatar
Does the engine crank?
If your engine doesn’t start you’ll want to check the basics. Check spark, fuel injector pulse and fuel pressure, volume and quality. Once you figure out what is missing, it will be easier to diagnose.
- Nick
shogun's Avatar
check BOTH fusable links, they are close to the batteries in the trunk in the red thick wire, hidden in plastic shrink, they could have haircracks.
Another problem area is the ignition switch behind the ignition lock.
See RealOEM.com Online BMW Parts Catalog
SHOGUN'S TRICKS AND TIPS FOR THE SEVEN SERIES
http://twrite.org/shogunnew/topmenu.html
Old 06-15-2013, 08:25 PM
