Go Back   Pelican Parts Forums > BMW Forums > BMW Technical Forums > BMW 6,7,8-Series Technical Forum
Send a message via AIM to michael733i Send a message via Yahoo to michael733i
BMW Roundel 733i onboard computer
Hi everybody! I've got a 1984 733i, and the onboard computer doesn't work. I've checked the fuses, but their good. Any help? Also, thanks for the advice on my last problem KC, worked like a charm!
-michael
Old 02-21-2003, 08:17 AM
Senior Advisor
Javier at Pelican Parts's Avatar
It's not working as in the display is out or faded? or just nothing? If display is faded or out try removeing it and replace the bulbs through the back of it. If it's giving incorrect info might be time for a new one, unless any one out ther knows how to rebuild the inners on these things.
...96 Chevy heavily Modded
such items include...
lil' pine tree air freshner....
duct tape rht front arm rest (i'ts falling)
zip tie holding in rear tail light....
hi concentrate windsheild washer fluid...
sticker of Speedy Gonzales..rear bumper...
Old 02-21-2003, 08:42 AM
yeah, I've got absolutly nothing comming up on the display. I don't really need it, but it would be cool if it worked. Thanks Javier. Peace.
mic
Old 02-21-2003, 08:51 AM
Senior Advisor
Pull the unit perhaps its just in the connection in the back.
Old 02-21-2003, 08:58 AM
KC Ron Carter's Avatar
There is an internal fuse
There is an internal fuse, usually gets popped if cables connected backwards during a jumpstart.
Later,
Old 02-22-2003, 12:55 AM
Banned
snowman's Avatar
The most likely failure is the display lamp. Its a $10 part, with $300 worth of labor. If you can replace it yourself its $10. No big deal, just lots of stuff to remove to get at the light.
to test check the display in the sunlight. Push some buttons. If you can see something in the reflection of the sunlight the computer is good, just the display lampl
Old 03-01-2003, 10:08 PM
