Go Back   Pelican Parts Forums > European Car Forums > MINI Discussion Forum
Where does this vacuum pipe go and how difficult is it to change?
Hi there
I have a 2007 mini copper S R56 UK car. It has a small leak from the vacuum line that plugs into the valve cover on the left hand side to the rear. It then disappears down under the induction manifold/air box. Where does it ultimately end and how difficult is it to change?
I've attached a photo showing the line in question
Thanks in advance
Adam
71 Bahia Red 2.2E (sold)
72 Silver 2.4 T (stock except for a 2.8 big bore kit)
69 Chartreuse 2.0E
Old 02-16-2017, 10:10 AM
Administrator
Dmitry at Pelican Parts's Avatar
Hey Adam - I've attached a diy tech article from our site that I think will be very helpful to you in troubleshooting the leak. If you have any additional questions, feel free to post a Comment just below the article and someone will get back to you with more details. Best of luck!
MINI Cooper R56 Valve Cover Replacement (2007-2011) | Pelican Parts DIY Maintenance Article
-Dmitry
Old 02-16-2017, 12:53 PM
That's great. Thanks for the help!
69 Chartreuse 2.0E
Old 02-16-2017, 12:56 PM
Administrator
Luccia at Pelican Parts's Avatar
Hello Adam -
Here is where it attaches to the valve cover. This image is figure 4 in the valve cover tech article Dmitry linked above. This is the one you're referencing, correct?
That is the vent tube/hose. It's not uncommon to have a leak from there. It connects from the valve cover to the lower intake manifold. It's part of the PCV system (Crankcase-Ventilation). Here is a better image of it and the part: Pelican Parts - 2009 MINI Cooper S Hatchback - Vent Hose. And here is a diagram that shows you how it is routed so that you can better understand its location to the lower intake manifold
Here is a thread where another individual reported an issue with it and where we discussed the location: http://forums.pelicanparts.com/bmw-mini/940120-vent-tube.html.
Let me know if you have any questions.
Old 02-16-2017, 12:59 PM
Yep that's the one very helpful, thanks.
69 Chartreuse 2.0E
Old 02-16-2017, 01:57 PM
Do you know if I can get to the intake manifold end by simply removing the air box?
Thanks in advance
69 Chartreuse 2.0E
Old 02-26-2017, 10:18 AM
Administrator
Thanks in advance
You might have enough room to get to it with the box removed. If not, you might have to remove a few more things/the manifold. Take a peek at our intake manifold removal DIY as figure 9 shows a good amount of room to get to the hose with the box removed: MINI Cooper R56 Turbocharged Engine Intake Manifold Replacement (2007-2011) | Pelican Parts DIY Maintenance Article.
Old 02-27-2017, 08:05 AM
Excellent, thanks.
69 Chartreuse 2.0E
Old 02-27-2017, 09:43 AM
