'07 R1200S
R1200S Rear Decals
Is there a source for these other than BMW?
![]() I just saw that my left side one was pealing ![]()
Cheers! |
If you have a very graphics heavy sign shop they can usually recreate the art. The small quantity might hurt you.
My bike came factory without the emblems.
Hard to see in pics but if the decal is largely intact, you might carefully apply a clear adhesive behind the emblem to repair. |
sɹǝʇndɯoɔ sǝʇɐɥ
My friend used to own a screen printing shop for apparel and stickers. There is time needed to create / cleanup the graphics file, man and set the equipment, and then run them off. I see other sources out there... https://www.motocolor.es/bmw/40-pegatina-r-1200-s.html
Mike '07 R1200S |
'07 R1200S
Thanks Gentlemen. I started using goop to remove one, and I think I like it better without. Unfortunately I ran out of both goop and shop towels. Move once it’s safe to leave the house
Cheers! |
'07 R1200S
Cheers! |
Registered Agitator
Mineral spirits & WD-40 works too.
sɹǝʇndɯoɔ sǝʇɐɥ
I took mine off years ago too. I like it better without. Less is more.
Mike '07 R1200S |
R1100s
I got some online
2009 HP2 Sport (sold) 2006 R1200s Remus exhaust, K&N, ilmberger carbon hugger, Ohlins, ABS, Heated grips, Wide Rear Wheel 2006 Subaru WRX STI S204 #318 / 600 Mercedes-Benz B-Class B180 BlueEFFICIENCY |
Gentlemen, I shouldn't 'jack hellfishtat's post, but the pics of his Akra and Mitch's Remus pipes got me thinking.
Would an exhaust system made for the R1200 S fit an HP2 Sport? The reason I ask is that the Akrapovic Evoline Ti system is no longer available for the HP2. |
R1100s
...wasn't me...
Headers are equally different story as they're routed under the engine instead of to the sides, in order to use belly-pan on HP2S, so that won't look right if you can bolt them on at all, being that HP2S is of Camhead variety as opposed to Hexhead R12S... I'm not sure if anyone other than Akrapovic bothered w full system for HP2S so options are really slim, especially since it's been over 10 years when last HP2S left assembly line... GL ![]() |
[QUOTE=Mitch1100;10805481]Try Sandbar
Thanks Mitch, will do. |
