-   BMW R1100S / R1200S Tech Forum (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/)
-   -   Plugged tire safe? (http://forums.pelicanparts.com/bmw-r1100s-r1200s-tech-forum/1062935-plugged-tire-safe.html)
Mattybingco 06-01-2020 06:00 PM
Plugged tire safe?
Is a plugged tire safe, or do I need to replace as soon as possible? I had a screw in my front tire - a brand new Michelin Road 5 - and would rather not buy another.
I’ve searched this but see varying opinions. Has anyone ridden one for an extended amount of time? The hole patched well, and isn’t in an awkward spot.
"A" 06-02-2020 12:14 AM
Safe enough for me when I know it's plugged correctly and I am operating my bike.
I don't know how well you did your plugging nor how you ride your vehicle.
It's always at your own risk.
Tirefriar 06-02-2020 12:17 AM
My personal opinion is for few hundred dollars I’d replace the tire. The only reason you’d plug it on a car is because you have 3 other tires for load distribution plus there’s a spare (usually) if the plug leaks ;-)
JimMoore 06-02-2020 01:19 AM
I'd ride with a plug in a rear tire. I'd swap out the front at my first opportunity. It's a bummer, those things are $$$.
bykemike 06-02-2020 03:20 AM
I plug my tires as required, so far no issues with any of them. Most extreme was on my GS during a trip and had three plugs in one hole but did make the rest of the trip with, again, no issues.
Like Jim I just let the rears go, fronts I'd rather change.
I haven't heard of plugs blowing out, leaking maybe.
giarcg 06-02-2020 05:23 AM
Used patch/plug at least 8 times... never a problem.
http://forums.pelicanparts.com/uploa...1591104156.jpg
va011101 06-02-2020 05:40 AM
I have no issues with riding with a plug, but I do closely monitor the air pressure. If I had a plug with a leak, I would replace the tire.
sgoodwin 06-02-2020 11:41 AM
Absolutely unsafe, you'll die under an 18 wheeler & be run over by 100 cars behind it.
Do I do it? Fuk yes, tires are expensive & I'm a cheap azz baztard. In reality I got about a 10% failure rate with just plugs, 0% with plug patches. Sometimes you just have no option but a plug to get home. Working on a couple thou in the rear on my zx, I do try to keep it under 200 though.
Mattybingco 06-02-2020 05:03 PM
So I think I’ll just bite the bullet on this one. Thanks fellas.
BadToTheBown 06-02-2020 09:45 PM
Originally Posted by bykemike (Post 10888220)
i plug my tires as required, so far no issues with any of them.
+1
Chris Canning 06-03-2020 11:47 AM
+1
When things go wrong the money you are talking for a new tyre is peanuts.
tm1100s 06-03-2020 01:21 PM
Patch to get home, replace ASAP.
Not mine, but who remembers this one?
http://forums.pelicanparts.com/uploa...1591219197.jpg
2wheelmike 06-03-2020 07:26 PM
The other pic that should be shown is Sergio’s bike on the trackstand that Tuna found on the roadside! LoL
tm1100s 06-03-2020 07:42 PM
I have that one, too. Gimme a few minutes.
tm1100s 06-03-2020 09:01 PM
http://forums.pelicanparts.com/uploa...1591246879.jpg
sgoodwin 06-04-2020 05:31 AM
Best use of a tube tv I've seen in a while.
terrym 06-04-2020 08:27 AM
Originally Posted by sgoodwin (Post 10891322)
Best use of a <strike>tube</strike> tv I've seen in a while.
Fixed it for you.
tomvv11 06-04-2020 12:49 PM
Ha, I thought it was a 1200S pannier that was extra deep because of all the space between seat and tire.
Mitch1100 06-04-2020 02:44 PM
I've been riding with a plugged rear tyre for about 5,000kms, but would not risk front. They were new tyres,...Murphy's Law!:rolleyes:
sgoodwin 06-04-2020 02:51 PM
Same reason I'm running a plugged rear on the zx. It had less than 100 miles when I picked up a screw. Had a bud with a 929 with 5 plugs in his rear tire. He wore it out with no problems.
