Rough As Guts
Within 2,000 kms of the last service my bike ('98 Yellow 35,000kms, no mods) was running like ****.
At idle it would range between 1200 - 1600 rpm, running rough at the lower revs. It was surging badly at low revs and at higher revs when cruising the engine vibrations were noticeably pulsing stronger and weaker.
I took it back to the workshop - they said they hooked it up to the analyser and couldn't find anything wrong but it now runs like a dream - smooth idle just above 1,000 rpm, no surging or pulsing.
I'd love to know what changed ... any suggestions?
Thanks - WAMO
'98 (Dec) R1100S Mandarin - 45,000 Km
Ulysses Member - "Grow Old Disgracefully"
Old 05-08-2003, 04:07 PM
CarlosT's Avatar
I once had that problem...turned out to be the throtle cable going to my right TB had gotten pulled during a wrenching session and wasn't seated. It's amazing how sensitive the TBs are to synch.
Old 05-08-2003, 04:12 PM
Thanks Carlos. That animated gif of yours has a very similar appearance to the pulsing feeling I was getting :-)
WAMO
Old 05-08-2003, 04:16 PM
Wamo/Carlos
So you guys are saying if I pull my throttle up out of the socket in will make my bike feal like Carlos Avitar
Dave Hopkins
'01 R1100SAL, KTM 400 EXC
1974 Husqvarna Vintage MX bike
Infinity Q45, Toyota Tundra
Old 05-08-2003, 04:37 PM
fiery's Avatar
Question Synch'ing
Love Carlos' Avitar ...
But just what is that purple thing behind the girl anyway ?????
Old 05-08-2003, 06:35 PM
That would be Carlos?
Dave Hopkins
Old 05-08-2003, 06:43 PM
shannonnunley's Avatar
Looks like a purple Barnie coming in for the kill
Check out BMW Forums at http://www.bmwforums.net/forums/index.php
Life should NOT be a journey to the grave with the intention of
arriving safely in an attractive and well preserved body, but rather to
skid in sideways, chocolate in one hand, martini in the other, body
thoroughly used up, totally worn out, and screaming,"'WOO HOO! What a ride!"
Old 05-09-2003, 11:06 AM
Flatbutt1's Avatar
If it felt like she looks, why did you fix it?
big blue tricycle
stare down the darkness and watch it fade
Old 05-09-2003, 11:30 AM
acidburn's Avatar
Barney good, Barney play and make mud in mud hole.
Except for a few cases the murderCycle rate is relatively low on this board, keep up the good numbers.
Old 05-11-2003, 07:25 PM
