Drive shaft seized...
Hi all,
Took my bike (2001 BMW R1100S non-ABS) in for the 60,000 Km service, and to make a long story short, the para-lever bearings needed replacing and my drive shaft was apparently seized in the middle. Thankfully they were able to remove the drive shaft, pull it apart, clean it up, lube it, and re-install it. Everything else looked good... (heading on a 6500 km ride in June). My question is, is the drive shaft being seized a common thing or has any one else ever encountered it? I googled it and didn't find much. The mechanic said it "looked like" someone had clear coated the splines and this caused the splines to basically glue themselves together. Any feedback appreciated! Shaun 2001 BMW R1100S Georgetown ON Canada Eh!
2001 BMW R1100S, Ohlins, Laser, K&N ... you know, the usual stuff.. “Aerodynamics are for people who can’ t build engines.” - Enzo Ferrari |
Initials & assault rifle
Since you said any feedback, find a new "mechanic".
2007 R12S | OHLINS | PRO PILOT | AKRA Ti | WOSSNER | FRK | BST | RT A-ARM | BRAKING | WERNER | K&N | RIZOMA | R&G | METZELER 1982 CBX | OLD SCHOOL 1969 H1 | QUESTIONABLE SANITY |
+1, sounds like gibberish.
Could have been a nitride coating, but that tends to reduce sticking, not increase it. Odd.
99 R11S w/ BBP, InDuct, Öhlins, PVMs, Braking, SJ-Filter, ZTech, HIDs D675 R90Cafe R60/2 M900 SV650-SS CBR150R XR125 & CRF175 Motards OnRoad OffRoad Cycles, Austin, TX: BMW, Ital, Suspension, Electrics Dealer for K-Tech, JRI, GP Suspension, Penske, Öhlins, RaceTech, Elka, Wilbers, IKON & Works www.ororcycle.com CMRA EXPERT #841 Various Formula 5, 6 & 7 championships 2006-2012 A3, Navigator, |
first i've ever heard of the half shafts seizing together on their splines. (i am assuming that is what you're talking about, otherwise it makes no sense at all).
"Wow I'm an idiot, thanks bikerfish!" Harleys are like opinions, every a-hole's got one! 2001 R11S "lite", with a few mods. 2009 F800GS. has a better saddle. and other stuff. (sold) 2016 R12GSW 3Black. wow. |
that whole thing makes about as much sense as the way they package doritos in japan.
(i still haven't figured this one out, and finally decided it was better not to try): ![]() i believe "find a new mechanic" would be the next good move. or just "find a mechanic", since i'm not sure your guy really is one. |
Uh....who me?
Hmmmm. 'tis a puzzlement.
Bob Hancock '20 KTM1290 SuperAdventure S, 2006 KTM 660RFR Dakar, 1966 Honda 305 Scrambler, 2019 Camaro 2SS 1LE, 2020 Chevy Trail Boss "There are times when good words are to be left unsaid out of esteem for silence." St. Benedict |
Talk Less, Say More
Location: Moab Utah. Home of wierd red & orange radioactive stuff... And 1 billion tourists.
Reminds me of Saturday Night Live this past weekend.
cRaIg CaRr 2000 Dyna FXDX, 2001 Sportster Sport, 2000 R1100S,2007 R1200S,2015 rNineT,2015 Gold Wing, 2023 F850GS,2023 R1250RS, 2017 Triumph T100, 2019 Jeep Rubicon, 2005 Jeep Sport, 2001 Corvette, 1978 Porsche 928. 2001 GMC Sierra 2500HD, 22 pairs of shoes. 24 bottles of beer. |
Registered Agitator
D a m n he's steppin' on his nuts......must be some weird jap custom. Does that mean all your chips are crushed?
Gasteropod Rider
![]() So you came in with a working bike and came out with the same working bike but a hefty bill ? |
It says- "DORITOS!! With the taste that will kick you in the nuts!!
Bikerfish, LMFAO!!!!
05 Boxer Cup Replika 06 ZX6R rev happy track whore |
No... It means eat Doritos and you will be able to crush you enemies nuts. The guy in the orange Dorito colored jump suit eats Doritos, and the guy in the yellow eats regular chips... Basic Japanese marketing 101.
2001 R1100SA Dakar Yellow & Black - Several Modifications
The only thing that makes sense about the driveshaft binding thing is that a binding drive shaft was most likely the cause of the paralever bearing failure.
Uh....who me?
Uh....who me?
If memory serves, back when changing out paralever bearings was all the rage (I did it), 30,000+ miles was about when it was happening. Bill Swartzwelder has experience wrenching this end of the R11S.....maybe he can chime in.
yeah, i would not conclude that the seized up driveshaft had any direct connection to the played out p-bearings. those bearings have to be considered a wear item unless you do as Roger recommends, and do periodic check (every tire change?) and adjusts on them. otherwise, its 20-35K and gone.
I think the two issues are unrelated.
Maybe, I say maybe, because I still don't know what 'seized in the middle' means But as far as checks go,, yes, every tire change is about right. Takes 5 seconds. I would've said unmaintained paralever bearings are good for 40-50k, but I've seen a few fail earlier, and a lot last a lot longer. A lot of variance between use/load/initial-condition. Life seems all over the map.
as does death.
Roger, with respect to paralever bearing wear, could the wear issue be related to how much riding you do on wet gritty roads versus riders to run on dry pavement all the time? This is just a thought since some say the bushings aren't much better for wear.
my first set failed around 20K- with no more than 50 miles (maybe) of dirty roads. My second set went out (still bearings) after another 35K, maybe 150 miles dirt. On JL bushings for last 30K, maybe another 150 dirt.
